    Static IP Wired Connection
    static wired connection
    • twistedd85
      twistedd85 last edited by
      Is there a way to set a static IP for a wired connection? All I can find in the recalbox.conf are places for wifi static IP and I'm not really using those.
        Zing Global moderator Translator @twistedd85 last edited by
        @twistedd85 I believe that there is no specific place for this, but, have you tried to edit this part of the static IP for the wifi and check if it doesn't work for the Wired Connection?
