    Shader crt-pi.glsl Raspberry Pi4 Recalbox 7
    Themes & Interface
    shader crt-pi.glsl pi4 recalbox
    3219
    • mkoff
      mkoff last edited by
      Hi. I managed to run overlays and shader crt-pi.glsl into recalbox 7 on raspberry pi 3b+. But the same conditions do not allow the shader to work on Raspberry Pi 4. Will a new working shader for Raspberry Pi 4 be written, deforming the picture with the stylistics like the old picture tube? Or can the old one also work with the new gpu under certain conditions?
      • mkoff
        7.0.1 - The problem is still there!
        • Zemus
          Zemus last edited by
          Still the same with 7.1.1
          The zfast crt shaders arent bad, but i like the old crt-pi shaders much more. 😞
            hello
            please go to /share_int/
            Download shaders.tar.xz
            unzip archive
            move all files in /share/shaders
            you need to erase files inside.
            and try again.
            Zemus 1 Reply Last reply Reply Quote 0
            • Zemus
              Zemus @acris last edited by
              @acris
              Ive done everything like you said, but no difference.
              Ive flashed a new 7.1.1 image to a second sdcard, but it is just the same
              crt-pi
              crt-pi-barrel
              crt-pi-mask
              ...still broke 😕
              • Pitch64
                Pitch64 Staff last edited by
                Do you have the file /share/shaders/lr/crt-pi/crt-pi.glsl? If not, you need to do again what @acris said above.
                Next release? Soonâ„¢
                • Zemus
                  Zemus @Pitch64 last edited by
                  @Pitch64
                  Everything where it belongs
                  Pitch64 1 Reply Last reply Reply Quote 0
                  • Pitch64
                    Pitch64 Staff @Zemus last edited by
                    @Zemus it should work in that case. If it still doesn't work, maybe try to restart?
                    Zemus BRDX 3 Replies Last reply Reply Quote 0
                    • Zemus
                      @Pitch64
                      It simply doesnt.
                      Like i said. If its a fresh install or my upgraded system...it doesnt work
                      • Zemus
                        @Pitch64
                        edit: now im just desperate and did acris advice even on the fesh install:
                        • Zemus
                          OK...
                          with this shader as source, i was able to fix the crt-pi shader for RPI4
                          https://github.com/libretro/glsl-shaders/blob/master/crt/shaders/crt-pi.glsl
                          I tweaked some values , so that the shader looks as close as the one on RPI3 (reduce moire effect, deactivate mask for real colour)
                          I didnt found a source for the barrel and mask shader (maybe special recalbox shaders?), so this was the only one i could fix for now.
                          Just copy the crt-pi.glsl file to /recalbox/share/shaders/lr/crt-pi
                          https://www.dropbox.com/s/elt6fxqmieh7pzh/crt-pi.glsl?dl=0
                          Hope i could help 🙂
                          • BRDX
                            BRDX Banned @Pitch64 last edited by
                            This post is deleted!
