    Shaders not working
    Emulator Arcade/PC/Console
    shaders
    • jestrogar
      jestrogar last edited by
      I tried both scanlines and retro and they do not work at all. If I select a system and select an specific shader it doesn´t work.
      I have tried witha raspberry pi 3b+ and a rpi 4 4 gb and nothing happens
      Do i have to change something in config files
      Many thanks
      nayok Zing 2 Replies Last reply Reply Quote 2
      • xxx2
        xxx2 last edited by
        hello
        i have the same issue.
        what i see / what i have done:
        1. after the start, on the menue where we can select the emulation station i entered the settings and set some recommended shaders and scanlines. dissabled the smoothing and pixel perfect.
        https://imgur.com/a/qWiTtPO
        (menue)
        https://imgur.com/a/HEc0v7G
        (game settings)
        https://imgur.com/a/gCuU6YJ
        (shortcut for ingame)
        [INGAME the directory inside the shaders for load/save was empty, no shaders or any files where shown]
        https://imgur.com/a/IjYJM2r
        (files are on the sd card -> could be seen inside the game settings)
        anyway. nothing changes. Restart didnt resolve my issue.
        • nayok
          nayok @jestrogar last edited by
          This post is deleted!
            Zing Global moderator Translator @jestrogar last edited by
            @jestrogar @xxx2 The shaders are working, see this topic:
            https://forum.recalbox.com/topic/21739/question-shaders-sous-pi4
            Perhaps this topic will help:
            https://forum.recalbox.com/topic/20805/tuto-mettre-par-defaut-le-shader-crt-nes-mini-glspl-ou-un-autre
            But, I believe it is a configuration problem, can you test with a clean image of Recalbox, without other modifications?
