    [RB7.0] Default controller not changed
    GamePad/GPIO/USB encoder
    [rb7.0] default changed
    • RetroVadus
      RetroVadus last edited by
      Recalbox 7 do not save the configuration on change default controller. I want to remove the default controller (GPIO) to default from the emulationestation menu, but the option is NOT saved on change.
      As workaround; It is possible, stopping emulationestation, edit the file es_settings.cfg and change the lines to default.
      <string name="INPUT P1NAME" value="DEFAULT" />
      <string name="INPUT P1GUID" value="" />
      Tested on raspberry pi 4b (4GB) with recalbox 7.0
      Hardware: Raspberry pi 4b (4Gb)
      Controllers: Connected via GPIO
      Video: HDMI to RGB (1280x1024, 5:4)
        Zing Global moderator Translator @RetroVadus last edited by
        @RetroVadus I don't have Rpi4 and I can't test this situation, but I saw that you opened several topics, one for each problem you encountered.
        Due to the high demand and low staff, it is difficult to answer everyone here.
        If possible, I suggest you join the Discord support channel:
        https://discord.gg/NbQFbGM
