    Solved Pi 4 - PS4 controller unpaired after restart
    GamePad/GPIO/USB encoder
    ps4 restart unpaired
    • twistedd85
      twistedd85 last edited by twistedd85
      After any restart it's as if the controller was never paired. I turn the controller on and it flashes white a few times, holds on white for a couple seconds, then turns off. I have to plug in the keyboard and add it again. Until it reboots it's fine, but for some reason it just won't remember it.
      This is using the Pi's built in bluetooth, wifi networking is disabled.
      Anyone else having this trouble?
      Edit: Disconnected the controller via holding the PS button and tried to reconnect, same thing. Flashes, holds, then quits and turns off.
      CrypticByte 1 Reply Last reply Reply Quote 1
      • CrypticByte
        CrypticByte @twistedd85 last edited by
        @twistedd85 I am having the same issue with my Pi 4 and the PS4 controller. Totally sucks having to keep a keyboard attached to the Pi just to reconnect the controller.
          Bug fix : https://gitlab.com/recalbox/recalbox/-/blob/master/RELEASE-NOTES.md
          • Fix PS4 pad pairing issue
          Update your recalbox tomorrow 21h00 (France) 9.00 pm
          twistedd85 1 Reply Last reply Reply Quote 1
          • twistedd85
            twistedd85 @acris last edited by
            @acris Sweet, thank you very much! Good to finally know it wasn't my doing. I was pulling my hair out.
