    Recalbox 7 brightness control Laptop x64/86
    recalbox brightness control laptop x6486
    • terri123
      terri123 last edited by
      Hello,
      Is it possible to bind the normal monitor brightness key (fn + F9) to work as brightness up and (fn + F10) brightness down)?
      The button (fn+f1) for mute is working
      The button (fn+f2) for volume down is working
      The button (fn+f3) for volume down is working
      Thanks for your nice work on Recalbox.
        Zing Global moderator Translator @terri123 last edited by
        @terri123 If the other function buttons are working, this one should work too.
        Unfortunately, if it doesn't work, I believe that nothing can be done, it would require a very specific customization job for each type of different hardware, which, as the team is small, is not viable.
        terri123 1 Reply Last reply Reply Quote 1
        • terri123
          terri123 @Zing last edited by
          @Zing
          Ok thank you for the Answer.
