    Xin-Mo Arcade Controllers
    Emulator Arcade/PC/Console
    xin-mo usb cont
    • peter-niceforo
      peter-niceforo last edited by
      Need some assistance.  I have been searching for a way to not use hotkeys with my Xin-Mo Arcahde buttons (20 buttons).  I want to map four buttons (Menu, Pause, Save and Exit).  I do not want to use any hotkeys.  Everything I edit the Rectroarchcustom.cfg file, it removed my changes.  Is there anyway around this?   My buttons all show up when I test them using JStest.   I have two buttons mapped under player one USB Controller and 2 buttons mapped under player two USB Controller.   All my wiring is correct.  All my buttons work except the four that I want to remap . I want to remap and not use a hotkey but the buttons as straight commands.  Does anyone know how to do this, please point me in the correct direction..   Thank you
      • i_am_millski
        i_am_millski last edited by
        Been battling with this myself, over here: https://www.reddit.com/r/recalbox/comments/41l9mf/escape_key_to_exit_emulator_instead_of_hotkey/ Can't get it to work though 😞 Hotkeys are awful ;(
        Geek, car nut, gamer, photographer and I enjoy pastries
        • peter-niceforo
          I had the Exit button working on RetroPie,  and started on the other buttons, but I like Recalbox with the Kodi interface.  There has to be a way of doing this.  If not, I might have to go back to Retropie.
          • mike-vromen
            mike-vromen last edited by
            Any progress on this ?
              @PNicefor > use https://github.com/recalbox/recalbox-os/wiki/How-to-use-custom-config-for-emulators-(EN) read joystick configuration for kodi : https://github.com/recalbox/recalbox-os/wiki/Kodi-on-recalbox-(EN)
