    can't get gpi case going
    cant gpi case going
    1975
    • westrud
      westrud last edited by
      gpi connected to network put in my ip address won't pull up file. really disgusted with this
        Zing Global moderator Translator @westrud last edited by
        @westrud follow this tutorial: https://recalbox.gitbook.io/documentation/basic-manual/getting-started/preparation-and-installation-of-recalbox/retroflag-gpi-case
        • westrud
          still can't get it to work, don't this part of the instruction "Open \recalboxgpi\share\system\recalbox.conf and make the same operation with the line ; wifi.key =
          You may change this file using nano via an SSH connection.
            @westrud I understand that you're stuck in this part, but I don't understand what problem you're having ...
            To connect via SSH:
            https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
            westrud 1 Reply Last reply Reply Quote 0
            • westrud
              westrud @Zing last edited by
              @Zing Open \recalboxgpi\share\system\recalbox.conf and make the same operation with the line ; wifi.key =
              don't understand this. i got up to changing the wifi key in Open the file recalbox-backup.conf, go to line starting with;wifi.key =
              the wifi key was already in there so i saved it, and i don't understand this next part at all was is ssh connection is that putty, and it only ask for my ip address
                @westrud
                putty
                Using Putty is an alternative, it is not a requirement, if you can edit the file without Putty, skip this step.
                you removed the ; the beginning of the line? It is essential that you remove it, otherwise it will not work.
                \recalboxgpi\share\system\ recalbox.conf
                Are two different files, did you edit the 2 as the tutorial says?
                You state that the password was already there, I believe you did not realize that there are two different files and you are editing only one file...
                • westrud
                  @Zing # secondary wifi (not configurable via the user interface)
                  ;wifi2.ssid=new ssid
                  ;wifi2.key=new key
                  i cut and pasted this out of recalbox backup is this what your talking about???????????????????
                  westrud Zing 2 Replies Last reply Reply Quote 0
                  • westrud
                    westrud @westrud last edited by
                    @westrud said in can't get gpi case going:
                    ;wifi2.key=new key
                    \recalboxgpi\share\system\ recalbox.conf i still don't this and were this is?????
                      ;wifi2.key=new key
                      No.
                      I deduce that you are a windows user, so use Putty as suggested, read this tutorial:
                      https://recalbox.gitbook.io/tutorials/access/root-access-via-terminal
                      And, watch this video to help (enable subtitles):
                      https://www.youtube.com/watch?v=Bt4aHZ2Xo2g&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=12&ab_channel=Recalbox
                      Understanding how it works, go back to the original tutorial:
                      You supposedly already did the first part of the process, and you are already in that part:
                      "Once EmlulationStation is up, you should be connected to your WIFI"
                      Use Putty to access this path "\recalboxgpi\share\system\recalbox.conf"
                      • westrud
                        @Zing Password:
                        Login incorrect
                        RECALBOXGPI login: r
                        Login timed out after 60 seconds
                        root
                        -sh: root: command not found
                        login as: root
                        root@192.168.1.67's password:
                        65qkx6h?ywf9
                        -sh: 65qkx6h?ywf9: command not found
                        -sh: \recalboxgpisharesystemrecalbox.conf: command not found
                        login as: root
                        Password:
                        Login incorrect
                        root
                        Login incorrect
                        Login incorrect
                        RECALBOXGPI login
                        isn't there any better tutorial this is awful it is not working i;m fed up wish i never bought this the place i bought knows nothing about it ............is there a place i can take this for help
                        !!!!!!!!!!!!!!!!!! under putty configurations under host name i put ip address saved sessions has winscp temporary session mean ???????????????????????? now it not saying log in
                          @westrud https://github.com/recalbox/recalbox-os/wiki/Network-access-with-WinSCP-(EN)
                          • westrud
                            @Zing I have the menu and one of the selections is updates not update system,
                            and Update the system". If a pop up display the message "an update is available" or "no update available" then your recalbox have an access to the Internet and so, to your local network
                            don't have this !!!! or don't know ow to access this
                              @westrud Sorry, I can't understand you. You need to describe better what you are doing and what is happening, otherwise I am not able to help you.
                              First, just to confirm:
                              What is your hardware?
                              What version of Recalbox are you using? (say the version, don't say "the last one")
                              Did you build your Recalbox yourself, or did you buy everything ready, or did you download a ready image from the internet?
