    vga 666 su raspberry pi3 b+ con recalbox
    Italiano
    vga 666 pi3 con recalbox
    • artusi73
      artusi73 last edited by
      buona sera. qualcuno puo aiutarmi a configurare la scheda vga666. di seguito copio il mio file config.txt grazie a tutti in anticipo.
      uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      disable_overscan=1
      uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      Sound output. Set to 0 or comment for autodetect, 1 for DVI, 2 to force HDMI.
      #hdmi_drive=2
      Using /etc/modules is deprecated and no longer supported on 4.4 kernel
      So manually enable audio
      dtparam=audio=on
      config_hdmi_boost=0
      force hdmi while the tv can take time before sending the signal on the hdmi output
      hdmi_force_hotplug=1
      uncomment for composite PAL
      #sdtv_mode=2
      uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      uncomment if you don't want the rainbow at startup
      disable_splash=1
      default CEC name
      cec_osd_name=recalbox
      Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=384
      avoid_safe_mode=1
      kernel=zImage
      Raise the first security limit up to 70° instead of 60°
      temp_soft_limit=70
        Zing Global moderator Translator @artusi73 last edited by
        @artusi73 Guarda se questo tutorial ti aiuta:
        https://recalbox.gitbook.io/tutorials/v/francais/video/crt/configurez-votre-ecran-cathodique-sur-le-bus-dpi-vga666-piscart-rgbpi
        artusi73 1 Reply Last reply Reply Quote 0
        • artusi73
          artusi73 @Zing last edited by
          @Zing grazie mille gli do un'occhiata e ti faccio sapere
