    My pc is 32 bit and won't boot
    bit wont boot
    • gamerz719
      gamerz719 last edited by
      I have an old pc that I want run this on through usb but when I try to boot it its just stuck on the booting into recalbox screen and doesn't finish booting
        Zing Global moderator Translator @gamerz719 last edited by
        @gamerz719 Burn the system image on a USB stick, and test it on another computer, if it works on another computer, it is some incompatibility of your computer's drivers.
        If it doesn't work on any computer, you're doing something wrong when recording, or you're not waiting long enough at the first boot (the first boot is slower, the system creates the SHARE partition at the first boot, so the bigger the storage device, more time consuming)
