    No sound with Recalbox 6.1.1
    sound recalbox 6.1.1
    • Ridera37
      Ridera37 last edited by
      Hi,
      I've been using successfully Recalbox 18.03.30 then 18.07.13 for a couple years.
      But since I installed 6.1.1, I have almost no sound: the sound works fine in the "intro" video (that mimicks the Playstation or Dreamcast boot), but after that no sound at all: no sound in the menu, no sound in any emulator...
      The sound section in recalbox.conf is:
      audio.device=auto
      ## Set system volume (0..100)
      audio.volume=50
      audio.bgmusic=1
      I tried hdmi and jack but still no sound.
      Any idea of what could be wrong ?
      Thank you for your help.
      • sroach
        sroach last edited by
        Maybe this will help:
        https://forum.recalbox.com/topic/14642/recent-update-no-sound/2
        • Ridera37
          "alsamixer" command showed that the default volume was 13, way too low. I raised it to 50 and it works fine now.
