    Enable Cheats
    Emulator Arcade/PC/Console
    enable cheats
    • Howlin
      Howlin last edited by
      Hi there,
      thanks to this great project I finished very well and played a lot of n64 by now. Thank you!
      However, in Mario Kart 64, there is a speed bug, which seems to be solved already:
      https://github.com/project64/project64/pull/607
      Therefore I need to enable cheats. I was searching here and in google for hours, but I do not know what to do exactly. In the cheats folder (in share) I created the folder n64 and created a file called Mario Kart 64 (Europe) (Rev A).cht (exact name of the rom). After a restart I start Mario Kart I try to get into the rgui. Then the game crashes (screen freezes).
      What am I doing wrong?
      Howlin 1 Reply Last reply Reply Quote 0
      • Howlin
        Howlin @Howlin last edited by
        in Super Mario 64 for example the rgui opens up, however the selected cheats still do not work (not manually added cheats).
          Zing Global moderator Translator @Howlin last edited by
          @Howlin I never used the cheats in Recalbox, but maybe these topics help you (they are a little old, so I'm not sure if they help):
          https://forum.recalbox.com/topic/14023/cheats-for-n64/2
          https://forum.recalbox.com/topic/2108/cheat-option
          https://forum.recalbox.com/topic/3579/cheat-mupen64
          • Howlin
            Howlin @Zing last edited by
            @Zing thank you! The problem was that I was not using libetro. With libetro it works fine now for the standard cheats. At the weekend I will give it a try again and work on the custom cheat for speed change.
            • Howlin
              anyone knows which file in retroarch is similar to the Config/Project64.rdb in project 64? This would solve the speed issue for Mario Kart 64 and would be great!
