    Transferring files from PC to Recallbox
    transferring recallbox
    7361
    • nickdj
      nickdj last edited by
      Good morning, I'm able to see the shared drive on my Windows 8.1 PC, however, when transferring files I'm unable to do this. The transfer speeds are slow and I keep getting "There is a problem accessing \RECALBOX\psx" Anyone else getting this issue and is there another way to get the files across? Nick
      RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
      • hstampfl
        hstampfl last edited by
        Hello Nick I have no speed problem accessing recalbox. On the raspberry pi I have the Edimax EW-7811UN plugged in. Heinz
        I started my retro passion in 1985 with my C64.....Today I have a small (retro) console collection including NES, SNES, N64, GC, Wii, WiiU, GB, GBC, GBA, NDS, DSi, 3DS, 3DS XL, 2DS, NEW 3DS, SMS, SMD, SG, SD, XBOX, XBOX360, XBOX ONE, PSone, PS2, PS3, PS4, PSP, PS VITA, VECTREX, C64, AMIGA 600, MIST Board, Turbo Chamäleon
        • nickdj
          Thank you for your reply. I'm using the Ethernet port on the Raspberry Pi 2 and although I can connect and browse directories it's having problems when transferring files. Windows just sit's at 0 byte/s sec. Might try another computer with Windows 7. Nick
          • nickdj
            I've discovered something strange when trying to transfer files from my Windows 8.1 system to Recalbox. I can transfer the files fine from my NAS drive using my Android phone but when trying to transfer a large file (e.g. 700MB) Windows appears to fail. I've tried disabling firewall settings to no avail. Transferring a smaller 30MB file is fine though. Is this unique to my computer or has anyone else experienced the same? Nick
            • digitaLumberjack
              Hi, Ok that's really blocking... Could you post and issue to https://github.com/digitalLumberjack/recalbox-os/issues with all info you can give ?
              • ralfomius
                ralfomius last edited by
                Hi, I had the same problem, too. Maybe you solved it meanwhile, as you posted nearly a year ago. Here is how it worked for me: After recalbox has booted, press F4 to end it. You see a black screen. Now press ALT+F2. You are now prompted for login. Login using user "root" and password "recalboxroot". Go to the root directory using "cd .." until you are there. Now go to the specific recalbox roms directory using "cd recalbox/share/roms/psx". Put your rom files on a usb stick formatted with FAT32, and plug it into your raspberry pi. Now you can copy the files using "cp ../../../../media/usb0/. ." Wait until the files are copied, then you will be prompted again. Unplug the usb stick and restart the box using CTRL-ALT-DEL.
                  voljega Banned last edited by
                  You can also use WinSCP to transfer your files and it should work, there is a known issue with network copies on large files
