    Solved Can't access NES ROM - Recalbox Manager
    cant nes rom recalbox manager
    1993
    • nidnal
      nidnal last edited by
      Re: Probleme beim übertragen von NES Roms via Recalbox Manager
      I seem to be having the same problem in the referenced post. I've got a Pi 2 and was using an older version of Recalbox (don't know the version but it was a few years old). I just installed 6.1.1 and now can't access the NES ROM via Recalbox Manager. The page never loads. All other ROMs seem to work as expected. Help?
        Hello
        dont use recalbox manager to transfert roms.
        you need to use share network or use usb stockage to stock your roms
        nidnal 1 Reply Last reply Reply Quote 0
        • nidnal
          nidnal @acris last edited by
          @acris hi and thank for replying quickly. Is this a known issue? I’ve never had issues with it before and it only is a problem with the NES folder. All other folders work like they did before I updated to 6.1.1
            It s a problem with manager and gamelist.xml
            • nidnal
              @acris ok thanks! I’ll try via share
              • nidnal
                nidnal @nidnal last edited by
                Just to follow up on this, using the network access via Finder worked. I was able to drop the .nes files into the NES rom folder and they are playable in Recalbox. Thanks @acris !
