    Remapped hotkey blank
    Emulator Arcade/PC/Console
    mameconfig guimissing
    • wkkriddlebox
      wkkriddlebox last edited by
      Hello everyone,
      Fairly new recalbox user her and working on an arcade box project with my daughter. I messed up in the Mame2003 emulator while trying to fix button mapping. I was changing the GUI hotkey but after it waited for the new combination it wouldn't accept any key presses. The emulator backed out to the system/core menu with that hotkey still blank. I cannot find a way to remap this hotkey as I need to either find the info/config for this, or use the hotkey that is no longer mapped.
      I am using a PS3 controller
      Dragon blaze 6.1 build
      For x86_64 machine.
      I can't remote in using the ip method and have my install booting off of a thumb drive with the roms mounted to a removable data drive.
      Any help would be greatly appreciated.
      Sorry if this has been answered before but I could not find it on here with a search.
      • zetof
        zetof last edited by
        Hello,
        You can use a keyboard to remap your controller.
        Zetof
        wkkriddlebox 1 Reply Last reply Reply Quote 0
        • wkkriddlebox
          wkkriddlebox @zetof last edited by
          @zetof I tried that but the hotkey to the Mame GUI is blank so the keyboard hotkey does not work either.
          My controller still works overall, I just have no way of reaching the settings menu for the Mame core now.
            Zing Global moderator Translator @wkkriddlebox last edited by Zing
            @wkkriddlebox When you remapped the buttons inside the emulator, a configuration file was saved, IF I AM NOT MISTAKE (check and back up first!), The path where this configuration file is saved is:
            \\SHARE\system\.config\retroarch\config
            There are several configurations, from several cores, you need to find the one you did wrong (MAME 2003 as I understand it), and delete it (BACKUP FIRST!), That way, the emulator returns with the original configuration.
            100.8k
