    any way to add roms from non local network?
    roms non local network
    1311
    • meme94
      meme94 last edited by
      my sister have a raspberry pi 3b+ but she dont know any thing in it , I try to enter recalbox shared fils to add roms for her . but Im in another place so can I enter to her files with any program by giving me the IP address of her recalbox?
      • olivierdroid92
        Hi
        You can try OpenVPN from you home to your sister IP's adresss then SMB or CIFS link
        meme94 2 Replies Last reply Reply Quote 0
        • meme94
          meme94 @olivierdroid92 last edited by
          @olivierdroid92 how can I do that .. I must open VPN on my pc ? isnt need to be in a local network or isnt need to be also in here raspberry?
          • meme94
            @olivierdroid92 I'm sorry, but I've never tried this before, is there any tutorial? it will help me a lot
            • olivierdroid92
              if you had never done this before, forget it.
              Should think to an alternative solution with USB stick and postal service
                Zing Global moderator Translator @meme94 last edited by
                @meme94 There is a somewhat strange option (which may not be the best option, but it may be easier), which is to make a remote connection to her computer, and from there access the Rpi and transfer the ROMs from her computer to the RPi in local network, you will only "operate" it from a distance ...
                If both are using Windows 10, there is a native tool called "quick assist" to make the remote connection, otherwise, there are specific programs for this, free for home use, you just need to do a little research.
