    Re map buttons in iMame
    map buttons imame
    • mc9625
      mc9625 last edited by
      Hi, Is it possible to remap buttons only in iMame4all? I would like to switch the B and A buttons of my XBOX 360 Wireless controller. Only in iMame, because they are correct in other emulators. Thanks
      • digitaLumberjack
        hi, normally all emulators are configured the same. Did you configure your xbox360 controller mapping the buttons as the snes controller ? https://github.com/digitalLumberjack/recalbox-os/wiki/Manual-(EN)#3---add-an-usb-controller
        • wsamh
          wsamh last edited by
          is there a menu on mame to make custom mappings?
          • digitaLumberjack
            Nope. You could edit the /recalbox/scripts/generateEmuConfig/createRetroarchConfig.sh in order to create a custom config for the imame4all emulator.
            • wsamh
              ok. cause I've configured my 360 controller as the snes controller, and the mappings are not right for the 6 button configuration. I have to use fba for now.
