    Exit emulator with sn30 pro?
    GamePad/GPIO/USB encoder
    sn30
    • ivwshane
      ivwshane last edited by
      I’m sure this is a stupid question but I cannot find the answer.
      I’m using an sn30 pro with recalbox 6.1.1. It paired incredibly easy and I didn’t configure any of the buttons.
      On my generic snes wired controller that I also did not configure, to exit one would press but the start and select buttons. This does not work despite all other buttons seemingly to be mapped similarly to the generic snes controller.
      The short version:
      How do I exit an emulator on a sn30 pro with default settings?
        paradadf Staff @ivwshane last edited by
        @ivwshane you can always re-rempap the controller to your liking of course, but if select isn't mapped as the hotkey, then it is usually on L3 or any of the extra buttons the controller has (the left one I'd say).
        • ivwshane
          I figured it out. The default is start + left analog button (as in pressing the stick into the controller).
            @ivwshane that‘s called L3.
            ivwshane 1 Reply Last reply Reply Quote 0
            • ivwshane
              ivwshane @paradadf last edited by
              @paradadf said in Exit emulator with sn30 pro?:
