    No Audio on hdmi only audio out jack
    audio hdmi
    • flynn14
      flynn14 last edited by
      Hi team
      Need help I have no sound through hdmi but have sound through audio out jack on pc can anyone help with this thanks
      • mundodisco
        mundodisco last edited by
        Hi,
        do you have by chance an ATI Radeon video card? I am having the same problem, and I read that in Batocera the same issue happens. The solution (in Batocera) appears to be: "HDMI Audio is disabled by default due to a black screen issue on some monitors. To enable it, edit on the USB key both boot/grub/grub.cfg and EFI/boot/grub.cfg files by adding radeon.audio=1 at the end of the linux line".
        However, in Recalbox did not work for me (or I did something wrong).
        The information I have just pasted is from:
        https://wiki.batocera.org/doku.php?id=supported_hardware
        Anyone has found a solution for Recalbox PC (v6.1.1) ?
        Regards,
        Gabriel
