    Tab mame menu not working
    Emulator Arcade/PC/Console
    tab mame
    3050
    • Genaker
      Genaker last edited by Genaker
      Hi there!,
      I just made a fresh install in my rpi3 and the tab menu is not working for mame.
      It used to work in previous versions, how can I access to the menu in order to remap buttons?
      Many thanks for your support.
      • jorgemagana
        jorgemagana last edited by
        Hello. I use "Mame2003 plus" as default core, and using a PS2 gampad, the TAB is in L3
        • Genaker
          How do I set the default core?.
          Thanks mate!.
          • GDEHON
            GDEHON last edited by
            Go to RetroArch (hotkey+B) > options :
            • display MAME menu : actived
            • legacy Remapping : actived
              May be
            • input interface : simultaneus (keyboard & retropad)
            • frameskip : 0 (Otherwise too fast games)
            • Genaker
              Thanks @GDEHON I've been able to access the mame menu following your instructions.
              It's much more complicated now...
              Thanks for your support, I really apreciate it.
              • GDEHON
                Happy for you 👍
