    Remote Control Compatibility for Kodi...?
    remote control kodi
    2718
    • steven-ohare
      steven-ohare last edited by
      So I have this remote control: http://www.amazon.com/HP-Infrared-Receiver-Discontinued-Manufacturer/dp/B00KDNIRYA/ref=sr_1_1?ie=UTF8&qid=1425761575&sr=8-1&keywords=hp+remote It works perfectly using OpenElec Raspbeery Pi 2 build, but when I attempt to use it (plug'n play style) on Recalbox, it doesn't work at all. Does anyone have any guidence on how to make it work with Recalbox build? Thanks in advance!
      • julien-morel
        julien-morel last edited by
        I Have the same problem with Yaste on Android. It haven't found the server to connect. I have enable the option in the setting of Kodi but no changes. Thanks 😉
        • digitaLumberjack
          Hi pals, I would ask you to create issues on github https://github.com/digitalLumberjack/recalbox-os/issues with all info you can give me. @ibiki I know yatse worked for some people, but i never tried by myself.
          • tank
            tank last edited by
            yatse: youhave to activate the webinterface in kodi settings (what you already did) and enter the ip adress manually in yatse or xbmc remote. it wont find it automatically, because zeroconf isnt active (i think)
            • julien-morel
              Ok thanks i will try that
              • nickdj
                nickdj last edited by
                Yatze works flawlessly for me once the web interface is enabled. The only thing I can't get working is the Fusion add-ons (TV Addons). It gives the same script errors I get with OSMC.
                RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
