    How to force Nouveau driver with legacy Geforce
    Emulator Arcade/PC/Console
    force driver legacy geforce
    • Ryu333
      Ryu333 last edited by
      Hello,
      Having mounted an old configuration to use it as a gaming PC, I would suspect that I was going to run into some problems and indeed, with the latest version of Recalbox (6.1.1 x64): the screen remains blocked on "Booting Recalbox ..."
      So I try the verbose mode in order to understand what is happening and having a Geforce 7600 GS I realize that the driver nvidia version 390 is loaded and finished with a "GLX is not supported" and "connection to X server lost ". Already, I tell myself that there is a problem because the 390 is not compatible with the 7xxx series but the 304 him yes (Not incorporated in Recalbox).
      So I'm looking to force the boot of recalbox with the Nouveau driver to take charge of my graphics card, I tried to remove "nouveau" from "blacklist.conf" in "modeprobe.d" and from blacklist "nvidia" but nothing helps: at the start it still tells me that Geforce is detected, "nouveau"is already blacklisted and that installing the 390 version of nvidia drvier.
      Thanks for your help !
      • Ryu333
        Nobody knows how to do it ?
        • rimolma
          rimolma last edited by
          @Ryu333 Have you found any solution? I'm having the same issue with Gefornce 7200GS. I even remove it and tried with the onboarded NVIDIA GeForce6100 but didn't work either.
