    Recalbox too slow
    too slow
    • vsztibe
      vsztibe last edited by
      Hello,   I have a raspberry pi 2 and today installed recalbox on it. I am a completely noob on this, I was trying Retropie but I was hassling too much with the controller, so I decided to try recalbox. It really looks better, but I could not do anything past the first install. Everything on the emulation station is EXTREMELY SLOW, I can't even open de system settings.   I am using a 16GB SD card class 10.   I searched about this kind of issue, but could find nothing. For everything else I see, recalbox should run smoothly on my raspberry, even without the overclock.   If you need any other information to help me on this, let me know.   Thanks!
        paradadf Staff last edited by
        I would start trying with a new installation. Did you formated your SD card properly? Where there any problems during installation? What SD card are you currently using?
        • vsztibe
          I was using a pre-release version (v3.3.0). I tried a stable release (v3.2.11) and it is working fine now. Thank you very much for your attention. 🙂
            Well, there shouldn't be any speed problem with the beta versions either.
