    Volume issue on kodi? (Solved)
    volume issue kodi solved
    • wsamh
      wsamh last edited by
      The volume keeps flickering on and off. It was doing it in the beginning. I switched it to alsa. It stopped for a little and now it is back. Is anyone having this problem?
      • wsamh
        I just found out it is related to my 360 controller. If i disable gamepad support in kodi, it fixes it. So is there anyway I can fix this or is this a bug?
          Hello try to active xboxdrv in recalbox.conf, reactive gamepad in kodi
          controllers.xboxdrv.enabled=1
          • wsamh
            It worked. thanks.
