    Reconfiguring inputs by config file doesn't work right anymore
    GamePad/GPIO/USB encoder
    reconfiguring inputs config file doesnt
    • Bloodsurfer
      Bloodsurfer last edited by
      I'm using config files in \\recalbox\share\system\configs\retroarch\nes<rom>.nes.cfg mostly to swap the A and B buttons for some games and to reconfigure the hotkey buttons, so I can fast forward by pressing hotkey + R2 for example.
      This was working fine in older versions before 6.0, it is no longer working correctly in 6.1.1.
      The config files look like this:
      input_player1_a_btn = 1
      input_player1_b_btn = 0
      input_hold_fast_forward_btn = 9
      input_rewind_btn = 8
      input_shader_next_btn = 7
      input_shader_prev_btn = 6
      menu_swap_ok_cancel_buttons = "false"
      What happens now when I press hotkey + R2 is, it does not only fast forward but also switches the shaders. So it is performing its original function as well as the new function I assigned via the config file.
      Has anything been changed regarding this feature, do I have to change something in the config files?
      100.8k
