    Setting up X-Arcade TankStick
    GamePad/GPIO/USB encoder
    tankstick
    • fredka
      fredka last edited by
      I am trying to set up an X-Arcade TankStick with Recalbox. Recalbox did not recognize it so I'm trying to manually configure it. However, I am thoroughly confused. First few times it stated that it did not recognize a device and even when I pushed a button (or two) nothing happened.
      Any help or instructions would be greatly appreciated. Thanks!
      Fred
        paradadf Staff @fredka last edited by
        @fredka have you read the wiki about it?
        https://github.com/recalbox/recalbox-os/wiki/XArcade-configuration-(EN)
        fredka 1 Reply Last reply Reply Quote 0
        • fredka
          fredka @paradadf last edited by
          @paradadf Thanks for responding! Yes, I did read that and that setting was already set to 1. I also update the pd3 toggle to off and the db9 to on. rebooted and I then was able to configure. Now my problem is that after I set each button, I highlight "ok" but nothing I click on the controller allows me to click it so it saves the settings.
          thanks again!
          Fred
