    Missing Main Menu . . .
    missing main
    • gamerson
      gamerson last edited by
      Ever since I updated to 6.1, when I push the Start button, I get the OPTIONS versus the MAIN MENU I am use to having. Is there a setting somewhere I'm missing or some setting I need to change in the .conf file?
        paradadf Staff @gamerson last edited by
        @gamerson the main menu appears only when on system view; the options menu when on game view.
        gamerson 1 Reply Last reply Reply Quote 0
        • gamerson
          gamerson @paradadf last edited by
          @paradadf Okay, how do I get it to system view? Before 6.1, when I pushed the Start button, it gave me the MAIN MENU but now that's changed.
            @gamerson where you can select which system you want to play, that’s the system view. Where you select which game you want to play, that’s the gamelist view.
