    6.1.1 PC img help
    6.1.1 usb img
    • kybur09
      kybur09 last edited by
      Having some trouble. I can down load the recalbox611.xy.sha1. That is how it loads for me. I delete the sha1 off end, it becomes rare file. Than it will not extract img because it says it is missing part... umm... I am not that stupid but I am stuck and can’t even start to use imgburn and a 4gb flash drive. I am trying to use PC as game room at home.
        paradadf Staff @kybur09 last edited by
        @kybur09 your message made me laugh, so funny. Back to your problem... you must download the right image, not the sha checksum. Loof for something with xxx.img.xxx in the name. Usually the biggest file.
        • kybur09
          kybur09 last edited by kybur09
          Thank you for the reply back. I am assuming it all started with the rare file. lol. I am trying the 32 bit from the recalbox page, dragonblaze. when it is done i will find out. As stated earlier, I have downloaded the 64 bit file like 4 times, and keep getting the same file with the .sha1 after it. Just keep trying. Once I get it, I am gonna save it and make like 3 copies so I don't lose it, lol, unless you have a link I am not finding. Have a good day.
          • kybur09
            Ok, so it is downloading still. For some reason I must have clicked on the sha1, not just the first part. So anyways, I assume the servers are super slow as it is only downloading at 50 to 90 kB/s. I have other things I can do from 1 to 6 mb/s. This is gonna take 2 hours, and after the first 3 times stopping, seems when goes into sleep mode, I changed screen to stay away for a hour. Should be running by tomorrow...lol. Thank you anyhow.
