    Custom GPIO Map doesn't work with Joy-IT Gamestation
    GamePad/GPIO/USB encoder
    gpio analog joy mkarcadejoystic joy-it gamestation
    • PinKing
      PinKing last edited by
      Hi guys,
      I have a Joy-IT Gamstation and I tried to configure the custom buttons. In recalbox.config I configured this:
      controllers.gpio.enabled=1
      controllers.gpio.args=map=5 gpio=25,22,26,21,3,5,20,19,14,16,15,13,4
      But after starting recalbox my buttons do not the right things.
      When I logged into the recalbox with ssh and write the following commands on the console:
      modprobe -r mk_arcade_joystick_rpi
      modprobe mk_arcade_joystick_rpi map=5 gpio=25,22,26,21,3,5,20,19,14,16,15,13,4
      /etc/init.d/S31emulationstation stop
      /etc/init.d/S31emulationstation start
      all buttons working as they should.
      Now I put this as a workaround in a script in /recalbox/share/System/custom.sh which is startet from /etc/init.d/S99custom after the recalbox is up, and this works for me, but my question is:
      Why do not work the parameters in recalbox.config? What did I overlook?
      I post this in german forum too, but there was no response. I hope somebody here can give me a tipp, so I do not need the workaround anymore…
      Greetings,
      Andy.
      • PinKing
        Hi guys,
        i think there is a bug in reading the args for custom gpios.
        I did following:
        In /etc/init.d/S26recalboxsystem I put some debug lines
        rb_gpio_configure() {
        settings_gpio_mk="$systemsetting -command load -key controllers.gpio.enabled"
        echo "Andy S26_2 : settings_gpio_mk: $settings_gpio_mk" 2>&1 | recallog
        if [ "$settings_gpio_mk" == "1" ];then
        settings_gpio_map="$systemsetting -command load -key controllers.gpio.args"
        echo "Andy S26_3 : settings_gpio_map: $settings_gpio_map" 2>&1 | recallog
        [ "$settings_gpio_map" == "" ] && settings_gpio_map="map=1,2"
        recallog "enabling mk_arcade_joystick_rpi"
        eval $config_script "module" "load" mk_arcade_joystick_rpi "$settings_gpio_map" 2>&1 | recallog
        else
        Then I set controllers.gpio.args to "doof"
        in /recalbox/share/system/recalbox.conf
        ; ------------ D2 - GPIO Controllers ------------ #
        ; GPIO Controllers
        ; enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
        controllers.gpio.args=doof
        After reboot I found this in
        /recalbox/share/system/logs/recalbox.log
        [ 5.88] Andy S26_2 : settings_gpio_mk: 1
        [ 5.90] ---- recalbox-config.sh ----
        [ 5.91] Andy S26_3 : settings_gpio_map: doof
        [ 5.92] enabling mk_arcade_joystick_rpi
        Ok, the reading of this gpio-arg was ok.
        Now I change the args to the parameters I need:
        ;------------ D2 - GPIO Controllers ------------ #
        ; GPIO Controllers
        After reboot this is the result in recalbox.conf
        [ 5.94] Andy S26_2 : settings_gpio_mk: 1
        [ 5.96] setting timezone to Europe/Paris
        [ 5.97] ---- recalbox-config.sh ----
        [ 5.98] Andy S26_3 : settings_gpio_map:
        [ 5.99] enabling mk_arcade_joystick_rpi
        No args in settings_gpio_map in log-file!!!!
        I changed the arg to only map=5 …
        ; GPIO Controllers
        and reboot the system...
        [ 6.03] Andy S26_2 : settings_gpio_mk: 1
        [ 6.05] setting timezone to Europe/Paris
        [ 6.06] Andy S26_3 : settings_gpio_map:
        [ 6.07] ---- recalbox-config.sh ----
        [ 6.07] enabling mk_arcade_joystick_rpi
        Again no content in settings_gpio_map!!!
        Now i don't wonder, why my custom gpio settings do not work.
        Can some comprehend this?
        Is this a bug or a feature?
        Greetings,
        Andy.
          it's know bug
          https://forum.recalbox.com/topic/18829/6-1-et-manettes-gamecon/21
          https://gitlab.com/recalbox/recalbox/blob/master/RELEASE-NOTES.md
          • Fix GPIO driver not loading (Arcade, GameCon & DB9)
          • PinKing
            Hi acris,
            thank you for this Information. I don't not understand french, so I didn't find the post with the solution for my problem. I excuse me, for wasting your time...
            Greetings,
            Andy.
