    Solved No auto connect of BT 8bitdo SN30 Pro+ after restart
    GamePad/GPIO/USB encoder
    auto connect 8bitdo sn30 restart
    • kbz
      kbz last edited by
      Hi all,
      I have:
      • 8bitdo SN30 Pro+ firmware 3.01
      • recalbox 6.1 without dongle, internal BT
      I can pair the gamepad with the PI, work like a charm.
      When I restart, I have to repair agin the gamepad, nothing seems to be kept/save/retain.
      Any idea ?
      Thank you
        Hello
        try manuel method : https://github.com/recalbox/recalbox-os/wiki/Connect-bluetooth-controller-manually-(EN)
        • kbz
          kbz last edited by
          Thank you Acris, worked!
          • akime1984
            akime1984 last edited by
            Mine is doing the same. Is this a bug in 6.1? My older 6.0 image works fine.
            • akime1984
              Following the steps in the tutorial fixed my auto reconnect issue. Thanks.
