    Solved GPI Case D-Pad not working
    gpi case d-pad
    6
    9
    8461
    • monkeydisko
      monkeydisko last edited by
      Hi,
      first of all thank you for the great image for the Retroflag GPI Case.
      Unfortunately, the D-Pad is not working for me with a fresh install of the latest "Raspberry Pi 1 / Pi 0 / GPI Case" image. All other buttons work just fine, even the back buttons.
      I tried a preinstalled image with retropie and the d-pad works fine in there, so no cable or other technical issues.
      I also switched between Axis and Hat mode - without success.
      Any other ideas?
      Thank you!
      P.S.: I'm using a Pi zero w inside the Retroflag GPI case.
        This post is deleted!
        • distantkitty
          distantkitty last edited by
          • monkeydisko
            Here are some config files. Maybe it helps to find a solution?
            hardware.log
            config.txt
            cmdline.txt
            recalbox-boot.conf
              Hello
              Try
              select+dpad up for 5s
              Or
              Select + dpad left for 5s
              monkeydisko 1 Reply Last reply Reply Quote 1
              • monkeydisko
                monkeydisko @acris last edited by
                @acris Select + dpad up did the trick!
                Thank you!
                • staabm
                  staabm last edited by
                  my dpad also doesnt work on a brand new gpi-case.
                  start/select and the buttons work (i can open the main-menu after bootup), but I cannot navigate the menu using the dpad.
                  already tried the suggested select+dpad-up(and left) for 5 secs suggestion but it doesnt work for me. any other suggestions (using Dragonblaze 6.1).
                  Adamow 1 Reply Last reply Reply Quote 0
                  • Adamow
                    Adamow @staabm last edited by
                    @staabm
                    Hi,
                    I don't know if you solved your problem but I found a way to solve mine, so I share it.
                    I experienced the exact same issue: install went fine and all buttons worked. But not the DPad.
                    So if every button works, including the shoulder buttons, here is the solution that worked for me: click start to open the settings menu. You want to get to the controllers settings but cannot because of the DPad. Just use the shoulder button that makes the selection jump a few items lower in the list. Use it until you get all the way down to the last item. And then use the other shoulder button once to jump back up little. It should put the selection right on the controllers settings item! You can now click on the button that selects (B I think). And configure a new controller (thankfully it's the first item in the list).
                    And you can then map 'up, down, left, right' with the DPad directions. Done.
                    Worked for me where all the suggestions above failed.
                    • RRandaxhe
                      RRandaxhe last edited by
                      If your Gpi is a newer model, the select button was changed to the start button, so select+DPAD LEFT becomes start+DPAD LEFT.
                      101.4k
