    PS3 gamepad stopped working
    GamePad/GPIO/USB encoder
    ps3 gamepad stopped
    2331
    • Aggarti
      Aggarti last edited by
      Hi! After the 6.1-DragonBlaze (RPI3+) update, the PS3 gamepad stopped working. When trying to reinstall writes that is not supported. How to be?
      • Shuu
        Shuu last edited by
        Hi,
        I also use a rpi3+ and a ps3 dualshock3 controller (not a sixaxis) on a fresh install of 6.1 and everything works very well.
        Few question:
        dualshock3 or sixaxis ? (but I don't know if it makes a difference.)
        fresh install ?
        work with cable ?
        another pad ?
        Aggarti 1 Reply Last reply Reply Quote 0
        • Aggarti
          Aggarti @Shuu last edited by
          @shuu said in PS3 gamepad stopped working:
          Hi,
          Few question:
          fresh install ?
          work with cable ?
          another pad ?
          Stood 6.0, yesterday was updated to 6.1 on wifi. After rebooting, the controller did not connect. In the controller settings, I deleted all BT devices and searched for new ones. The controller was found, but when you try to install the system gave a message that it is not supported.
          • Shuu
            Shuu last edited by
            If it worked yesterday, it's probably not a hardware problem.
            Since the release of 6.1, I read several times that updating 6.0 to 6.1 could cause problems.
            Make a clean update perhaps? (it's fast if the games/save/bios are on usb key)
            Or wait for someone who has gone through the same update process rather than a fresh install, has the same problem and find a solution.
              paradadf Staff @Aggarti last edited by
              @aggarti how are you trying to pair PS3 controllers?
              • Aggarti
                @shuu
                Good. Thanks!
                • Aggarti
                  Aggarti @paradadf last edited by
                  @paradadf said in PS3 gamepad stopped working:
                  On the PS3 controller I press the button with the PS logo, in the system menu I choose the option, it seems, BT controllers search...
                  • Aggarti
                    I think I understand what's going on! First you need to configure the controller through the wire:)
                      @aggarti you don't pait PS3 Controllers through the ES menu.
                      You need to:
                      1. Connect them through the usb cable with your recalbox
                      2. Wait about 10 seconds
                      3. Unplug the cable and press the PS button
                      After a few seconds the controller usually vibrates and gets paired. If not, try again the above procedure.
                      • Aggarti
                        Thanks!
                        • Shuu
                          Shuu last edited by Shuu
                          I I forgot to ask if you followed the tutorial ! 😄
                          If someone with the same problem passes here here here is the link:
                          https://recalbox.gitbook.io/documentation/getting-started/manual-recalbox-6.0-dragonblaze/controller-configuration#ps3-controllers
