    Final Burn Neo System 24
    Emulator Arcade/PC/Console
    neo
    1898
    • jorgemagana
      jorgemagana last edited by
      Hello everybody! Recently FBN added support for System 24 games, about 8-9 games like Hot Rod, Rough Race, Crack Down, etc, but they don't work in Pi3, only color screen appears but nothing happens, the .dat file contains these "new" games, but they don't run...
      • barbudreadmon
        barbudreadmon @jorgemagana last edited by
        @jorgemagana i didn't test those on arm, maybe there is an issue with this arch, i'll check later today.
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
        jorgemagana 1 Reply Last reply Reply Quote 1
        • jorgemagana
          jorgemagana @barbudreadmon last edited by
          @barbudreadmon Thanks!
          • barbudreadmon
            @jorgemagana found & fixed the issue, thanks for the report
            • jorgemagana
              • AgedLove
                AgedLove last edited by
                @barbudreadmon In addition to system 24 games, the following 'new' games also don't work in Recalbox's FBANeo :
                Last Mission (World revision 😎 lastmisn 1986 Data East Corporation No launch
                Slither (set 1) slither 1982 Century II 'CMOS Invalid'
                Birdie Try (Japan revision 2, revision 1 MCU) birdtry 1988 Data East Corporation No launch
                I use the right romset
                • barbudreadmon
                  barbudreadmon @AgedLove last edited by
                  @agedlove said in Final Burn Neo System 24:
                  Thanks for the report, it seems there is an issue with this one.
                  lastmisn & birdtry are working fine with right romset & latest FBNeo for me, furthermore you are mentioning "No launch" which is typical of wrong romsets. FYI those 2 games got redumped around 2 weeks ago, those new dumps won't work with the version of FBNeo bundled in recalbox 6.1 (because it was released prior to that), i have a feeling you are using those new dumps and didn't verify your romsets with clrmamepro & the dat file provided in your recalbox. It might be safer to be sure before making the statement that you have "the right romsets". If there is really an issue with those 2, it appears to be fixed with latest FBNeo.
                  AgedLove 1 Reply Last reply Reply Quote 0
                  • AgedLove
                    AgedLove @barbudreadmon last edited by AgedLove
                    @barbudreadmon yes i tested with latest dat and romset checked accordingly with clrmamepro but from the fbneo github 😉
                    So it's also fixed, i'll recheck later
                    • jorgemagana
                      Tested System 24 games with 6.1.1, now the games load fine but are unplayable, slow performance. I am using Rasp 3b+
                      • barbudreadmon
                        @jorgemagana said in Final Burn Neo System 24:
                        slow performance
                        Yeah, i just spent 2 hours trying to lower the requirements of this driver, but it just doesn't seem possible for the rpi3b+ to run this system in FBNeo at full speed (i think the synchronization between the 2 m68k cpu is the bottleneck in this driver). You'll have to either upgrade your device (i tested, the odroid xu4 run this system at full speed), or use another emulator (maybe mame2003-plus would do better ?)
                        jorgemagana 1 Reply Last reply Reply Quote 0
                        • jorgemagana
                          @barbudreadmon thanks for your effort!
