    Solved 6.1 Save States and Hi Scores Lost for NeoGeo
    Your recalbox
    6.1 scores lost neogeo
    • andyj34
      andyj34 last edited by
      Hi
      Just recently upgraded from Recalbox v6.0 to v6.1.
      I had two (2) saved states; mslug2.state and mslug2.state8, for states 0 and 8 respectively.
      Before the upgrade I backed-up of these files as contingency as well as the high score files.
      Since the upgrade though the above save state files remain intact/untouched, the emulator is not loading the save states as before.
      In addition the high score files are also not being recognised.
      Can someone provide a solution as to reinstate the usage of the saved state files otherwise i'm going having to play the game again to reach the last level!!
      Regards
      • Fishou
        Fishou last edited by Fishou
        Hello, sorry for the question, but in which folder did you put back the save and hi-scores?
        It seems that while previously hi-scores were in recalbox\saves\fba_libretro\fba , now it saves and loads from the recalbox\saves\fba_libretro\fbneo folder, due to the fact the core changed name.
        Also the states seems to be directly in recalbox\saves\fba_libretro
        Maybe it's the reason, though I am not sure about the states.
        EDIT: I assumed you were using the fba_libretro folder, if you are using the neogeo one, I am not sure if it has the same principle, but that may be worth looking into.
        Si vous débutez, je vous recommande de lire le glossaire.
        Je fais actuellement le Surchargeur RA, il est fourni tel quel, sans garanties.
        • GKM
          GKM last edited by
          Hello @Fishou ,
          thanks! As soon as I get home I try too (I had the same problem and I didn't understand). Excuse me one thing: why does retroarch still call fba_libretro if now it is actually fbneo_libretro?
          Fishou 1 Reply Last reply Reply Quote 0
          • Fishou
            Fishou @GKM last edited by
            @gkm As far as I know for recalbox, it's for backward compatibility reasons (renaming the folders could be tricky to handle, maybe there are other reasons too but I don't know).
            Let me know if this fixes anything ^^
            • GKM
              GKM last edited by GKM
              I got it.
              Thanks! it was enough to move all the content from fba to fbneo from the fba_libretro folder.
