    Solved Can't access Recalbox.conf through direct access
    recalbox.conf ssh root access frontend screen
    • granderjoree
      granderjoree last edited by granderjoree
      Recalbox latest version / Raspberry pi 3 Model B
      Hello! I was trying to access the Recalbox.conf through the frontend screen by pressing F4 to quit, pressing ALT+F2 to get to the terminal.
      I typed in /recalbox/share/system/recalbox.conf but I can't access the file.
      it only shows this...
      I could access this in the past but now I don't get whats wrong with it.
      Please help. Thanks a lot guys!
        voljega Banned @granderjoree last edited by voljega
        @granderjoree well you just typed the name of the file, and it's just a text file, if you want to edit it, you need to use a edition commande before like nano : nano /recalbox/share/system/recalbox.conf
        • granderjoree
          @voljega It worked! Thanks for the quick reply! Thumbs up! 😄
          101.4k
