    PSX games not running in Recalbox 6
    running recalbox
    • zenarola
      zenarola last edited by
      Hello. I have been playing PSX games in previous versions of Recalbox, but after upgrading I'm no longer able to play them. The system recognizes the games, but after starting them it returns to the frontend. I have installed all four bios files (scph1001, 5500, 5501 and 5502). I have tried with .bin & .cue format and .pbp. I would appreciate any help. Thanks in advance.
        Zing Global moderator Translator @zenarola last edited by
        @zenarola Are the BIOS recognized by Recalbox Manager?
        zenarola 1 Reply Last reply Reply Quote 1
        • zenarola
          zenarola @Zing last edited by
          @zing Yes they are. I checked the MD5 checksum to verify that the files match also.
          • olivierdroid92
            Check with other roms as i have no issue.
            I can confirm all is ok for me
              @zenarola Are all BIOS with a green "V" in Recalbox Manager then? What is your hardware? How did you upgrade the Recalbox version? Are you sure the ROM aren't the problem?
