    Solved USB CEC Adapter not creating ttyACM device
    usb cec adapter creating ttyacm
    • timmerman
      timmerman last edited by timmerman
      Same problem as another user:
      Another issue (same hardware as previous post), this time with libcec not creating /dev/tty* for my usb cec adaptor. Possible udev issue (missing rule)? Or kernel driver missing?
      I have had this adaptor working on the last stable on another box.
      Thanks again.
      dmesg | grep -i cec
      [ 1.943138] usb 1-4: Product: CEC Adapter
      [ 3.267137] input: Pulse-Eight CEC Adapter as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:2548:1002.0001/input/input14
      [ 3.267239] hid-generic 0003:2548:1002.0001: input,hidraw0: USB HID v1.10 Mouse [Pulse-Eight CEC Adapter] on usb-0000:00:14.0-4/input2
      cec-client
      No device type given. Using 'recording device'
      CEC Pa**er created - libCEC version 4.0.2
      no serial port given. trying autodetect:
      path: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4
      com port: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4
      opening a connection to the CEC adapter...
      DEBUG: [ 11] Broadcast (F): osd name set to 'Broadcast'
      ERROR: [ 3514] error opening serial port '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4': Is a directory
      ERROR: [ 3514] could not open a connection (try 1)
      ERROR: [ 6349] error opening serial port '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4': Is a directory
      ERROR: [ 6349] could not open a connection (try 2)
      ERROR: [ 8239] error opening serial port '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4': Is a directory
      ERROR: [ 8239] could not open a connection (try 3)
      ERROR: [ 9499] error opening serial port '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4': Is a directory
      ERROR: [ 9499] could not open a connection (try 4)
      unable to open the device on port /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4
      NOTICE: [ 10504] connection opened
      ERROR: [ 10504] could not start CEC communications
      Some devices that use ttyUSB work, but devices like an Arduino Mega or the CEC adapter which uses ttyACM don't work.
      I'm on version 6.0. In the previous version everything worked.
      <pre><code># dmesg | grep -i cec
      </code></pre>
      • timmerman
        I found the problem. After recompiling with "CONFIG_USB_ACM=y" in the kernel config file everything works.
        Can this be added into the new release?
        • timmerman
          I've created an issue on GitLab for this.
            paradadf Staff @timmerman last edited by
            @timmerman thanks for debugging it! The changes have been merged to master.
            timmerman 1 Reply Last reply Reply Quote 0
            • timmerman
              timmerman @paradadf last edited by
              @paradadf said in USB CEC Adapter not creating ttyACM device:
              Great! Thanks @paradadf for your work.
