    Solved GPIO with RPi 1 (26 PIN GPIO)
    GamePad/GPIO/USB encoder
    gpio pin
    2363
    • Raketenmann
      Raketenmann last edited by
      Hi there,
      I cannot configure my (BarTop) Joystick.
      see: https://github.com/recalbox/mk_arcade_joystick_rpi/blob/hotkeybtn/README.md#pinout
      And here is, what I tried in my .conf file.
      (of course I also tried standard config)
      ------------ D2 - GPIO Controllers ------------
      GPIO Controllers
      enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
      controllers.gpio.enabled=1
      mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
      controllers.gpio.args=map=5
      Custom mk_gpio arguments,
      map=5 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk for one controller,
      map=5 gpio1=pin11,pin7,pin13,pin15,pin19,pin21,pin22,pin18,pin16,pin12,pin-1,pin-1,pin3
      map=5,6 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk gpio2=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk for 2 (map=5,map=5,6)
      map=5,6 gpio1=gpiox,gpioy,gpioz,.....,gpiou,gpiov gpio2=gpiox,gpioy,gpioz,.....,gpiou,gpiov
      where gpiox,gpioy,gpioz ... are NOT pin numbers on the connector, BUT location gpio numbered as in
      https://www.raspberrypi-spy.co.uk/wp-content/uploads/2012/06/Raspberry-Pi-GPIO-Layout-Model-B-Plus-rotated-2700x900.png
      Set pin to -1 to disable it
      controllers.gpio.args=map=5 gpio=11,7,13,15,19,21,22,18,16,12,-1,-1,3
      MCP configuration : GPIO and MCP can be used together. You can mix them.
      map=0x20,0x21 for 2 mcp23017 on i2c bus
      #controllers.gpio.args=map=0x20,0x21,5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,-1 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,-1
      It just doesn't work at all.
      Any ideas?
      Thank you!
      Christian
      • ian57
        ian57 Staff last edited by
        @Raketenmann You need to check with a ssh connection and linux commands that le mk_arcade module il well loaded. After, use evtest to test each button and joystick direction. Which rela**e of rpi1 do you have ? 512B b+ ?
        • Raketenmann
          Hi IAN57,
          thanks for the quick answer.
          The module is loaded - it seams to me:
          Module Size Used by Tainted: G
          mk_arcade_joystick_rpi 4442 0
          And here is the output from the evtest:
          Input driver version is 1.0.1
          Input device ID: bus 0x15 vendor 0x1 product 0x1 version 0x100
          Input device name: "GPIO Controller 1"
          Supported events:
          Event type 0 (EV_SYN)
          Event type 1 (EV_KEY)
          Event code 304 (BTN_SOUTH)
          Event code 305 (BTN_EAST)
          Event code 307 (BTN_NORTH)
          Event code 308 (BTN_WEST)
          Event code 310 (BTN_TL)
          Event code 311 (BTN_TR)
          Event code 314 (BTN_SELECT)
          Event code 315 (BTN_START)
          Event code 316 (BTN_MODE)
          Event type 3 (EV_ABS)
          Event code 0 (ABS_X)
          Value 0
          Min -1
          Max 1
          Event code 1 (ABS_Y)
          Value 0
          Min -1
          Max 1
          But no reaction on any input.
          RPi Version: Pi Model B Rev 2
          (thats the output from cat /sys/firmware/devicetree/base/model)
          Thanks!
          CHristian
          • ian57
            @Raketenmann which release of RB are you running because with 6.0 I made a mistake in the mk_arcade module preventing pi0 ans pi1 to work with gpio see here https://github.com/recalbox/mk_arcade_joystick_rpi/issues/71. Please try the last beta 3 or DL the new mk_arcade_joystick_rpi.ko at https://mega.nz/#!y9kCEI7I!7HdyKzhWS4HhfVgpvj7SM9RbnLwMUlGXoUqcxzuFCQM
            replace the /lib/modules/4.14.62/extra/mk_arcade_joystick_rpi.ko with the new one and enjoy 🙂
            • Raketenmann
              Hi Ian,
              it might be a stupid question. But how to copy the file?
              cp: can't create '/lib/modules/4.14.62/extra/mk_arcade_joystick_rpi.ko': File exists
              Sure. But if I try to delete it - even with root / su
              rm: can't remove 'mk_arcade_joystick_rpi.ko': Read-only file system
              BTW - Recalbox UI shows there is an update available if I switch to "BETA". But the download fails.
              Thank you!
              Christian
                OyyoDams Staff @Raketenmann last edited by
                @raketenmann mount -o remount,rw /
                • Raketenmann
                  Thank you Gentlemen!
                  Works now.
                  Not perfect. But I received a first feedback while configure controls. Rest will be easy and fixed in the config file later today.
                  You may close this!
                  Great support.
                  Thanks!
                  Christian
                  • ian57
                    ian57 Staff @Raketenmann last edited by
                    @raketenmann Do not try to update :), It would downgrade to 6.0 I think 😉
                    • Raketenmann
                      Thx!
                      First I tried to update. Did not worked.
                      Thats why I changed the File by using the shared folder and SSH.
                      Now- as it works - I will keep it until the next official release where you hopefully take care on RPi 1 users.
                      Again: great support.
                      Thx
                      CHristian
                      • ian57
                        @raketenmann I hope to :), but Pi0 is very close to Pi1 of first gen... so it shoulb be 😉
