    recalbox from noob
    recalbox
    • jackman
      jackman last edited by
      hello,
      my recalbox shows black screen.
      i can hear the sound.
      i tried changing the hdmi_boost to 7 or 8, but i still get a black screen.
      i read that there is a problem with recalbox and noob os - is there a solution? or should i just burn another sd card?
      is there a way to operate the recalbox from raspian?
      thank you
        Zing Global moderator Translator @jackman last edited by
        @jackman Recalbox is not compatible with noobs, so you're having problems. It was backwards compatible, but it is necessary to update several things to make it compatible again, so there is no exact prediction for that to happen.
        As far as I know there is a program similar to noobs, called PINN, which is compatible with Recalbox, you can try it if you want.
