    Sony PVM 9042QM and raspberry Pi 3
    sony pvm 9042qm
    • danje57
      danje57 last edited by
      Hello,
      I would like to use my Sony PVM 9042QM with my raspberry Pi3 model B.
      Sony PVM 9042QM: https://archive.org/details/sony_PVM-6041QM_9040ME_9042QM_9045QM
      I bought this converter HDMI to VGA
      https://www.amazon.fr/gp/product/B01ARLD1HU/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
      and another cable VGA to BNC
      https://www.amazon.fr/gp/product/B0033AF5Y0/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
      I add a T BNC to add video synchro signal
      https://www.amazon.fr/gp/product/B07FMCQ1Z5/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
      I've connected all things like that:
      Raspberry Pi ==> Hdmi ==> VGA ==> to BNC + T ==> to Sony PVM
      On my PVM I've the RGB signal in my IN BNC and the T in my Video In entry
      When I start recalbox, the menu appear without ptoblem, but when I try to start a game, the display is not correct I've lot of noise
      I configured my config.txt file from this site:
      https://www.retrorgb.com/rpi240p.html
      disable_overscan=1
      hdmi_ignore_edid=0xa5000080
      hdmi_pixel_encoding=2
      hdmi_force_hotplug=1
      hdmi_cvt=320 240 60 1 0 0 0
      hdmi_group=2
      hdmi_mode=87
      DISABLE_SPLASH=1
      config_hdmi_boost=4
      dtparam=audio=on
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=256
      Do you have any idea?
        Zing Global moderator Translator @danje57 last edited by
        @danje57 Well, the Rpi3 and video adapters usually give same problem ...
        The Tutorial to modify the video in Rpi3 is in this link:
        https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        You need to modify the global.videomode in Recalbox.conf, with the value corresponding to your monitor. But as I said, video adapters usually give problem, incompatibility ...
        • idarius
          idarius last edited by idarius
          Hello !
          For the globalvideomode, i think it's already on defaut, which is fine.
          it will use whatever resolution you have forced in the config.txt, in this case DMT 87, the custom resolution you choose above.
          in the case you want to be more clear in the config :
          • global.videomode=DMT 87 HDMI
          • system.es.videomode=CEA 6 HDMI
          (because emulationstation will be too small in 320 240, you need 640 x 480 interlaced)
          for the resolution i dont use 320 x 240, but 1920 x 240, (1920 can fit a lot more emulator with original resolution.)
          this is my config.txt :
          hdmi_cvt=1920 240 60 1 1 0 0
          avoid_safe_mode=1
          disable_overscan=0
          config_hdmi_boost=4
          hdmi_drive=2
          hdmi_group=1
          hdmi_mode=6
          hdmi_force=1
          kernel=zImage
          After that, you have to create a config file in the retroarch folder, like this for each emulator :
          nes.cfg
          aspect_ratio_index = "22"
          custom_viewport_width = "1792"
          custom_viewport_height = "240"
          custom_viewport_x = "63"
          custom_viewport_y = "16"
          which define the exact viewport for the emulator.
          Sorry for my english, tell me if you need more info 😉
