    Solved PreInstalled roms does not load - Pi 3B+
    preinstalled roms does
    • fattout
      fattout last edited by
      Hello everyone,
      I know this problem has already been discussed a lot of times but i can't find my problem :s
      I could complete everything on the installation of recalbox but when I try to launch a game preinstalled (Doom , .. I tried it all) then i see a black screen for a few seconds and then i'm back on the EmulationStation screen.
      Here is my config :
      • RaspBerry 3b+
      • Arcade Buttons with GPIO connection (i can correctly map the keys)
      • HDMI output with converti DVI on my screen
      • RecalBox ( 6.0-DragonBlaze ) - Official version
      • Emulator : I changed nothing in the default configuration. It seems weird that all the games for all emulators seems not working ...
      I tried with 2 different SD cards but the problem persists
      Other USB devices connected : A keyboard but same problem when i plug it off.
      Thanks a lot !
        Hello
        Do you try demos roms others emulators ?
        Snes ? Nes ? Gba ?
        Prboom requiered wad files please read file.txt into roms folders
        • OldGreg
          OldGreg @fattout last edited by
          @fattout : Have you configured your joystick before playing ?
          RPi 3B+ with Recalbox 6.0
          • fattout
            I tried all the roms pre installed (Machines are multiples : GBA / Amiga ,/ PC Engine / .. )
            • I configured my joystick yes.
            I tried again with an xbox pad and unpugging the joystick and i still have the same problem 😢
            • fattout
              Ok I tried on a new SD card and it works ...
              I close the topic
