    Wired XBOX360 controller boot loop?
    GamePad/GPIO/USB encoder
    wired xbox360 boot loop
    • rick311
      rick311 last edited by
      I have my recalbox set up and it works fine with PS3 controllers. I put another together and got wired XBOX360 controllers which work fine, as long as I don’t keep them plugged in when I start the system.
      If I have them plugged in and start the system, the loading screen starts, then the screen goes black, then the loading screen comes back and goes black over and over again.
      If I have them unplugged, start it up, let it load, THEN plug them in, they’re fine.
      Is there a work around to this to keep them plugged in the entire time and not have to worry about a boot loop?
      Your help is appreciated as I am pretty new to this still.
      • Bkg2k
        Bkg2k Staff last edited by
        That's a power supply issue. Your power supply does not deliver enough current.
        • rick311
          Turns out that was exactly what the issue was! Thank you SOO much!
