    advance mame is very slow on Recalbox 6.0
    Emulator Arcade/PC/Console
    advance mame very slow recalbox
    3070
    • rizzie
      rizzie last edited by
      Hello~
      The advance mame core of this recallbox 6.0 was slowed down. Games that worked well in previous version were slower in this version. The most popular games are Virtua Fighter and Numan Althletics 2. Can I move the advance mame core back to the previous version? I am sorry that my English. Thank you in advance.
      • DreyMIX
        DreyMIX last edited by
        I have the same problem too. In the previous version they worked wonderfully!
        • DreyMIX
          Hello, I tried to install the image of Recalbox 6.0 on another Raspberry Pi 3 B (not B +) with a 32 GB Sandisk. After starting the system for the first time, I tried not to change anything except the controls. So I put the "Championship Sprint" roms in the "mame" folder and selected the AdvanceMame core. I confirm that there are still problems with slowdowns and crackling sounds
            Hello
            advanceMame is not a core but a standalone emulator,
            Dont forget, to modify mame game option in emulationstation to use this emulator.
            Game option > mame > emulator : advmame , core : advmame and use correct romset : mame 0.106
            • DreyMIX
              Hi, I put both "emulator" and "core" on advancemame and I already use the 0.106 mameset as I used on the recalbox 4.1. But on many roms despite the 4.1 with advancemame, the system is slowed down.
              Sorry for my english.
                @DreyMIX
                very strange, because advmame is the same version both recalbox 4.1 and recalbox 6.0
                DreyMIX 1 Reply Last reply Reply Quote 0
                • DreyMIX
                  it is indeed strange at this point. But as I wrote above, I tried to install it on another raspberry (the one I used previously for the recalbox 4.1 with the same SD and the advancemame worked wonderfully), without touching anything, putting the roms "Championship Sprint", for example, and I immediately notice the slowdown (it will be for the FPS or something else, unfortunately I can't tell you). Have you no way to test yourself too?
                  • DreyMIX
                    DreyMIX last edited by DreyMIX
                    Hello @acris ,
                    I did several tests with some parameters (advmame.rc.origin):
                    device_video auto
                    display_resizeeffect none
                    display_rgbeffect none
                    but the lag persists. Can you by chance check if the "Championship Sprint" or "Arkanoid Returns" roms (for example) actually work without slowdowns?
                    Thx!
                    • DreyMIX
                      DreyMIX @acris last edited by
                      @acris Sorry, is there really no way to solve the problem? I have also reported the bug on github, but no one has deigned to answer, even if only to say: ok let's check or let you know or something.
