    Problem with WiFi connection.
    wifi connection
    • A Former User
      A Former User last edited by
      Hi everyone, I finally bought the Raspberry Pi 3 B + and a nespi + case. Spectacular!!! I have only one problem: every time I start Recalbox I have to re-enter the WiFi password otherwise it won't connect. The ssid name and pass are stored but not connected. I also tried to activate and deactivate the wifi several times (as also suggested on this forum) but nothing. Moreover every time I put the pass I have to wait even more than 2 minutes before the WIFI ACTIVE message appears. Can someone help me?
        Zing Global moderator Translator @Guest last edited by
        @melomitru Try this:
        https://forum.recalbox.com/topic/17879/dragonblaze-wifi-fix-and-presenting-retroarch-panel-project
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @Zing last edited by
          @zing thank you, I Will try this.
