    DragonBlaze WiFi Fix and presenting Retroarch Panel Project
    dragonblaze wifi fix presenting retroarch
    • Pepeu
      Pepeu last edited by
      Hi everyone.
      For those who are having problems with the WiFi losing connection after restarting, I would like to present you a solution:
      https://gitlab.com/recalbox/recalbox/issues/816
      When saving, a new line for the SSID is being created on recalbox.conf. If you manage to delete that, it is going to work fine.
      I would like to present you my project as well. I called it Retroarch Panel. It is just on Portuguese by now, but you can check it by visiting:
      https://paulorobertoelias.com.br/2019-06-01-projeto-retroarch-panel/
      https://github.com/PRElias/retroarch-panel
      The ideia is to get all your games from the gamelist.xml files and show on a searchable grid and allowing you to export as an Excel file.
      Best regards to all of you
