    N64 can not start games in any of the three emulators
    n64 start three
    3596
    • elschnorelli
      elschnorelli last edited by
      Hello everybody! I have an issue with rb pi2 and recalbox 3.3 beta 17 (also before). Whenever I start any N64 game, after a time the emulationstation will be displayed again and the screen resolution has adjusted to the one I configured in the N64 settings. Does anyone has a solution for this behaviour? Thanks!
      • omnija
        omnija last edited by
        Is the rom zip or unzipped?
        • elschnorelli
          the roms are unzipped. does it make any difference? e.g. I tried the .n64 format.
          • omnija
            The n64 emulator didn't run my zipped roms, so if your rom was zipped it could of been the issue.
            • omnija
              Out of curiousity, did you change any information about the n64 in the es_systems.cfg?
              • Anonpebbles
                Anonpebbles last edited by
                Hi i am having a similar issue, I can't get any n64 games to run. I just get a black screen. I can return to the menu but no games work. Do I have to alter something in the es_systems.cfg?
                  That happened to me quite a few times. Just rebooted the Pi and it was fine. What kind fo monitor are you running ? Does it support DMT 9 ? What games did you try ? I can tell you Mario and Mario Kart run fine (well, almost fine. At least they can be launched)
                  • Anonpebbles
                    I've tried both mario kart and mario 64, I thought maybe it was the tv so i changed the screen settings to CRT screen on recalbox configuration to see if that would change anything, this did not work.. Not sure what else i can do
