    extend recallbox dive size
    • abdulla566
      abdulla566 last edited by
      Greetings
      i put recallbox img into 120GB Flash drive and it divide it into 3 drives on of them is recallbox drive it take 2 GB with less than 400mb free space. i try to resize it so i give it more space so i could add new theme or access it to add and remove games quicker but i couldn't
      i try mini tool partition but could change the size of the drives. hope someone helps
      sag508 1 Reply Last reply Reply Quote 0
      • sag508
        sag508 @abdulla566 last edited by
        @abdulla566 This isn't recommended, but format the third partition with the remaining space on it as FAT32. Then in settings, have recalbox point to that partition, restart, then you can add whatever you want.
        It isn't recommend, because in the event of system or card failure, you'll lose everything. It happened to me, and I now keep everything stored on an attached USB flash drive.
        • p0cth
          p0cth last edited by
          here is a simple and reliable solution, which requires a clean installation
          format and resize support PiNN
          https://pinn.mjh.nz/
          PINN is an enhancement of NOOBS for the Raspberry Pi.
          https://sourceforge.net/projects/pinn/
          Rpi4B 4Go Rev1.2, No overclock, Stockage interne SanDisk Ultra Class 10 64Go, Argon Fan Hat, 2 gamepads Sony Dualshock 3, Wireless Combo MK270, Alim Officielle Pi4, Ethernet No Wifi, Bluetooth natif
          • ninjaw
            ninjaw Banned last edited by
            diskgenius let me resize (actually I had to bakup recreate and restore on bigger space). "Add or remove quicker" what the hell do you have in mind ? this looks like a very useless and dangerous idea. Also ... what the hell were the two other answers ??
