    Remap NES buttons
    remap nes buttons
    • joe-berndt
      joe-berndt last edited by
      Is it possible to remap the buttons for each game system?     The default mapping for NES is that the two buttons are next to each other horizontally so that (NES "B" button) is set to B and (NES "A" button) is set to A. I would like to set the buttons vertically so .....(NES "B" button) to Y  and (NES "A" button) to B.      Is it possible to change this globally for this system (only for NES) without messing with the other emulators? I hope i'm explaining this clearly.  Thanks in advance!
      • digitaLumberjack
        Hi, it's posible if you use a custom config file for the nes. it means too that you cannot get the auto configuration of the joysticks and other things like shaders etc anymore on this system : https://github.com/recalbox/recalbox-os/wiki/Custom-controller-mapping-for-specific-system-(EN)
        • digitaLumberjack
          I just opened that : https://github.com/recalbox/recalbox-os/issues/554
          • joe-berndt
            Great! Thanks! I'll try it
            • soysanti
              soysanti last edited by
              by the emulator menu I could not. so I had to edit the file
              for anyone looking to remap buttons on a SNES controller:
              1º create file in:
              \192.168.1.xxx\share\system.config\retroarch\config\remaps\FCEUmm
              name file: FCEUmm.rmp
              input_player1_btn_b = "8"
              input_player1_btn_y = "0"
              input_player1_btn_a = "10"
              input_player1_btn_x = "9"
              input_player2_btn_b = "8"
              input_player2_btn_y = "0"
              input_player2_btn_a = "10"
              input_player2_btn_x = "9"
              input_libretro_device_p1 = "1"
              input_player1_analog_dpad_mode = "0"
              input_libretro_device_p2 = "1"
              input_player2_analog_dpad_mode = "0"
              input_libretro_device_p3 = "1"
              input_player3_analog_dpad_mode = "0"
              input_libretro_device_p4 = "1"
              input_player4_analog_dpad_mode = "0"
              input_libretro_device_p5 = "1"
              input_player5_analog_dpad_mode = "0"
              in SNES controller:
              0= botton1
              8= botton2
              3= start
              6=left
              7=right
              5=up
              4=down
              regards
