    EmulationStation no longer start after...
    longer start after
    1786
    • Eternity57
      Eternity57 last edited by Eternity57
      Hi there,
      I've got an issue since I had use XML scrapper from my PC to scrape my rasppi recalbox 6.0 share drive rom. The tool had stop emulastionStation remotly during the scrapping and now (since an update) no longer be able to works on my PC (filelist xml issue or something like that).
      Since I've got welcome screen recalbox with pac man emoji and I also got access to web console where I try to restart emulstation or simply start emulstation but I only see a quick (1 or 2 seconds) emulstation splash screen and then it comes back to recalbox screen.
      Please find here the support log file : https://file.ac/nbEmeVY-1aI/
      Need help 😉
      Many thanks in advance
      Eternity
      • Eternity57
        Sorry after two try it seems that log file is not available ... does not know why...
        • Eternity57
          I've check logs from web console and I do not see any error !? may be it is normal status set up by a specific option on emulationStation start option ?
          • Bkg2k
            Bkg2k Staff @Eternity57 last edited by
            @eternity57 Try deleting the gamelist.xml files (one per rom folder). You may start by deleting the gamelist from the system you scrapped last
            • Eternity57
              Thank you !!!
              Yes It could be this because es.log stop on this
              [2019/05/11 08:32:35.825] (INFO ) : creating thread for system nes
              [2019/05/11 08:32:35.825] (INFO ) : creating thread for system ngp
              [2019/05/11 08:32:35.825] (INFO ) : Parsing XML file "/recalbox/share/roms/amiga600/gamelist.xml"...
              [2019/05/11 08:32:35.825] (INFO ) : creating thread for system ngpc
              [2019/05/11 08:32:35.825] (INFO ) : creating thread for system o2em
              [2019/05/11 08:32:35.825] (INFO ) : creating thread for system oricatmos
              [2019/05/11 08:32:35.826] (INFO ) : creating thread for system pc98
              [2019/05/11 08:32:35.826] (INFO ) : creating thread for system pcengine
              don't know what's next ? I meam next system...
              Next folder is pcenginecd but I do not scrappe it ? neither previous one above... only snes, mame, ...
              • Eternity57
                It works after having deleted all gamelist file...
                some other error log found on es folder
                es_launch_stdout.log
                Powering on HDMI with explicit settings (CEA mode 4)
                Powering on HDMI with preferred settings
                /usr/bin/retroarch -L /usr/lib/libretro/fbalpha_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg /recalbox/share/roms/fba_libretro/gunbird2.zip
                running command: /usr/bin/retroarch -L /usr/lib/libretro/fbalpha_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg /recalbox/share/roms/fba_libretro/gunbird2.zip
                mkdir(/recalbox/share_init/cheats/cht/FB Alpha/) error: Read-only file system.
                Failed to create directory: "/recalbox/share_init/cheats/cht/FB Alpha/".
                and in es_launch_stderr.log
                ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory
                Would that means something for you ?
