    Recalbox 6.0 DragonBlaze Raspberry Pi 0 W
    recalbox 6.0 dragonblaze
    3414
    • Einklinker
      Einklinker last edited by
      Hello,
      Why is fw 6.0 on the raspberry pi zero w so laggy?
      The menue is very laggy and I’ve tried SNES but is not playable. Very laggy and the sound is Horror.
      I will buy next month the retroflag gpi case and I would make the card ready.
      I tried Retropie and it run better.
        Hello @Einklinker
        disabled recalbox manager.
        Einklinker 1 Reply Last reply Reply Quote 0
        • Einklinker
          Thanks, that is the problem?
          • Einklinker
            Einklinker @acris last edited by
            @acris sorry, but is not better
              Scavy Global moderator @Einklinker last edited by
              @einklinker Hi, most of SNES roms are not playable on a rpi0w. This card is not powerfull enough to get a valuable experience of the snes emulator.
              Concerning the V6.0 of the OS, i haven't tried yet, but your feed-back is interesting me as i'm planning, like you, to acquire the GPi case in a close future. The OS is laggy ? Did u install a theme or are u using the original one ?
              Concerning the emulated systems, which ones did you test ?
              Thanks.
              Einklinker 1 Reply Last reply Reply Quote 1
              • Einklinker
                Einklinker @Scavy last edited by
                @scavy the os 6.0 is clean installed and the menue is laggy. I have tried with overclocking but not good, the restart have a problem and you become a message from os “up to date” and nothing happen.
                The SNES have a game installed named donkey kong on os 6.0 and the game is laggy. Another haven’t try because the menue is to laggy for me. I think RetroPie is better for zero and the os 4.1 can’t find in the web for zero.
                  @Einklinker
                  try to disabled : popup music, 720p screen
                  no used rewind and try other core.
                  • Einklinker
                    @acris i have tried and overclocked with 950 mhz and the start need 1:38:40. The menue is slow and maybe you have an older version for zero to test it?
